Please can you release sensor ID is esp8266-6546546?
Many thanks,
Jakub
Many thanks,
Jakub
perfect Thanks, all is working well. The only I am searching for, maybe the forum helps, if I got the counter how many days PM10 50 peak is reached as of EU max allowed is 35.
Hi Could you release ID 6787947 for me?
Thx in advance
Jarek
Hello could you release 6788074
Thank you
Hi Ricki,
Could you please release sensor ID is esp8266-7020743?
Many thanks!
Hi
Could you please release sensor ID is esp8266-1332524?
Just curious: Why are some id’s taken yet? ![]()
Hi, could you do the same for esp8266-13442321
Hey.
Could you also please release esp8266-717887?
Best Regards!
can you confirm that sensor 33076 (ChipID: esp8266-7429633) is online again?
Could you please release sensor ID is esp8266-14200076
I’ve released the chipID.
@Berry_DE_HAAS Please use the links provided with the notification mails (api-rrd.madavi.de).
If you can see actual data there then the device should be online again. So you don’t have to wait for an answer here …
Hi, could you please release esp8266-13442321
I am setting up the dust sensor. The wifi and driver has been installed into the computer. And the Wifi and dust sensor had been assembled. Hower, when figure “Connect to the WiFi network created by the station on your computer or smartphone. Wait until the connection is established” but it did not work. What do I need to do next?
Thanks
Hi @ricki-z ,
could you please release esp8266-1559032
Thanks a lot!
@Hotay-NDThi , can you see the wifi hotspot the device should open at startup? Its only active for 10 minutes, so you may need to restart the device again.
Thank’s a lot @ricki-z
