Hi @keysim86 , please decide if you have a device with our firmware (esp8266) or one with the smogomierz firmware. Only the right system choice will work with your firmware.
The registration for id esp8266-8905141 is restored. YOu shoiuld see it in your account.
Hello @ricki-z
Thank you, it works.
Could you please unregister my sensor ID?
Thanks in advance;)
Please release id esp8266-74B586
TIA
Hello @VukoDrakkainen , coulld you please tell me if you have a Smogomierz system (which you also tried to register) or a device with our firmware? Only one of them will work, and by registering both you will block another user which may have the system with the other ID!
Hi @l4omecha , this is not a valid chipID when using our firmware. We have no hexadecimal chipIDs.
Hello, now i have Smogomierz firmware installed.
Hi, thanks for you reply. This is Tasmota running.
@VukoDrakkainen I’ve released the chipID.
@l4omecha There is no registration with that chipID 74B586. Please check the instructions for the Tasmota system. But we can’t really help you with that as we don’t know this system.
Hi, I finally replaced the sensor with the new one
but I should replace the configuration id of the Pomeziameteo station SENSOR: #71908
old id:5220886
new id: 12076361
@Pomeziameteo Hi, I’ve replaced the chipID in your device registration with the new one.
I thank you so much Happy Holidays
Hello Ricki,
I have the same problem that my ChipID is already registered. Could you Please reset the Sensor. SensorID: 6426925
Thank you and Kind Regards
@Markus1234 please check your mails. I have sent you a question to this.
Hello Ricki-z
I have two problems with the sensor.
The first is that the sensor 937490 is registered but cannot be found on the account or on the card. (Please delete the sensor so I can re-register it)
The second error is that I can’t send sensor data to maps.sensor.community but the sensor can be found on open sensorMap.
Kind regards Roland
Can you release the ID esp8266-1118295. The sensor was registered and then deleted by mistake.
Thanks,
Stephane
@Stephane_Gueibe I’ve released the chipID.
Hi Ricki, have the same issues, bought the sensor via ebay, pls reset so I can do a new register with a new position. Sensor ID is esp8266-896543.
Thanks in advance.
Hans
Hi @Hans_Seyfried , I’ve released the chipID.
