Hi community, I have recently change my internet connection and so also wifi router. I’m not more able to see my sensor as he try to connect to wifi with the old references. Is someone know how to proced to reset wifi and be able to reconnect to sensor and setup new parameter?
thanks for help.
please restart the device. It should then open a hotspot again (for 10 minutes). If you can see the hotspot then you can follow the instructions for the “first time” configuration:
https://sensor.community/en/sensors/airrohr/#Configure
I have tryed many time to only restart without succes. I finally play with the reset buttom on controler, it has reopen intial wifi connection and give me a chance to setup well to the internet router. Thanks for help.
