Hi ,
I’ve setup my unit and the SDS 11 is working fine , but temp \ pressure sensor not working
Like here : BME 280 not found the unit is not found
I thought it might be this : NodeMCU flashing additional info so erased and reflash to the bme-280 latest firmware but still no avail
I have soldered all pins , I have a multi meter and have checked Continuity between the pins and the board to make sure solder is good , have measured 3.3 v across GND and VCC , tried different gnd and 3.3 rail
Thanks
Paris
