This sensor ID is already registered
@OorbaN I’ve released the chipID. So you can reregister it with the right prefix and the right components.
Hi @ricki-z
I am trying to register my air quality sensor on the platform, but I get a message saying that the ChipID is already registered.
Could you please release this ChipID so I can register it under my account?
  • ChipID: 2926446
Thank you very much for your help.
Best regards,
Imi
I think I have the same problem like everybody else.
I lost conection with my device and I tried to delete and reinstall it.
The ID is 5802227
SDS011 and BME280.
Thank you in advance.
Hello @Imi ,
please check that you add no component a second time. There are two components as default, the SDS011 and the DHT22. If you have a BME280/BMP280 then change the line with the DHT22 instead of deleting it and adding a new line.
The mentioned chipID isn’t registered at the moment.
@Boil_Kolev please read my answer to Imi . The chipID 5802227 isn’t registered yet.
Hello
I entered a different type instead of SEN5x during registration, so only fewer PMx values ​​were entered into the system. I tried to fix it, but then only pressure and temperature worked. I deleted it and started over, but I got the message “This sensor ID is already registered”.
My sensor ID is: 13108931
Controller: Iotroniq IOT-AQS3xx/AQS4xx air quality sensor
Can you help?
Thanks in advance.
Hello @Loerinc I’ve released the chipID. So you can register it again.
Hello @ricki-z Thank you very much for your help! The SEN5X setting was not working, but I found the solution here: sensor-data-reporting-error/3634, I think it works fine now.
