This sensor ID is already registered
Can you please reactivate sensor 1358013 ?
My friend deleted the sensor but it was easy repair.
Thank you
Aart
I’ve restored the sensor registration.
Hi, I’m trying to set up a new sensor, but am also getting the message ā€˜already registeredā€. It looks like you’ve been able to help others with this issue - could you also help with this one? The Sensor ID is 15852454.
Many thanks!
Hi! I have a similar error, I couldn’t include my sensor and I deleted it. Sensor ID: 2925659.
sensors SEN55 for air quality and temperature and humidity and DPS310 for pressure. Thank you in advance.
Hello @Margaret_Gold ,
could you try again to register the sensor? I could not find a registration fo the mentioned chipID. Please check that each component is there only once.
I have the same issue. Deleted my sensor and thought I can re-add it. Now it I am getting ā€žThis sensor is already registeredā€œ.
Can you please delete mine so I can re-add? Sensor ID is: 16382579
Thanks a mil in advance.
Hi @luzidl I’ve released the mentioned chipID.
Hello! I deleted my sensor too :frowning: Pls restore it!
sensor ID: 2927180
cpu: esp8266
Hello! I have the same problem. Can you please delete it?
My Sensor ID is: 14115377
esp8266
@Risto_Topalov There is no registration for this chipID. Could you please check that there is only one component per type (PM, temperature, humidity, …) when you register your device?
Hi, can you release my chip ID? 16005377
Hey can you please also release my ID? 563835
Hi @StephanS I’ve released the chipID.
Hello! I deleted my sensor. Can You restore it!
esp8266-333442
KK
@Korneliusz_Kwaczak I’ve send you a PM.
I am trying to register my air quality sensor on the platform, but I get a message saying that the ChipID is already registered.
Could you please release this ChipID so I can register it under my account?
  • ChipID: 14817698
  • Sensor type: SDS011
Thank you for your help.
It’s a mistake, sorry
@ricki-z I deleted my sensor esp8266-1747938 some time ago and now I want to restore it and appears as already registered. Could you please help? Thanks!
@ricki-z Hi can you please delete sensor 9046688 I need to add pressure and temperature modelu. Also my sensor is registered with smogomierz prefix (PMS7003). I’m not able to see it on the map even though it registers data in the DB. Can we somehow map it to the correct name?
best regards,
Jacek
@jcgomez I’ve restored the device entry.
