Hi!
Can you release my sensor please?
esp8266 2795330
Thx
Hi!
esp8266 2795330
Thx
Hello
I started a new project Rhedenseluchten.nl to form a citizen network for pm2.5 sensors. I took over around 8 sensors ESP8266 from the Arnhemspeil community. Now it turns out that all the sensors I try to register are already registered. The last I tried is #14462369 ESP8266 that will not register with sensor community. How can I get this sensors available again?
Sensor ID
14462369
12778565
12780377
1340452
14470822
14469352
12785408
7997252
sincery grateful if someone can help me en make these sensors available again to the community.
Goos Hageman
Hi @ricki-z and all admins!
Can you please release all my sensors too?
esp8266 6366265
esp32 6366265
I think you only have one of these, either the esp8266 or the esp32. And its very unlikely to get both with the same chipID.
(So you are blocking actually another user to register his/her device).
So please tell us which module you have and I will release this and delete the other.
Thank you for clarifying. I only have one ESP8266. However, I mistakenly tried registering it both as ESP8266 and ESP32, using the same ChipID, and removed it a couple of times during the process. Apologies for the confusion caused by this.
Could you please release the ESP8266 with ChipID 6366265 and remove any conflicting entries?
I’ve released esp8266 6366265.
Hello, I treid to connect my noise sensor ID1779749 , had the wrong sensor type selected. I could not change it, so I tried to remove the sensor from my account.
Now I can’t connect te sensor annymore, what can I do?
Hello @Berry_DE_HAAS , I’ve restored the device registration and changed the components to a noise sensor and a BME280.
@ricki-z Thanks a lot, have a good weekend and a happy new year.
@ricki-z is it possible to get a third option in the hardware configuration , I only have 2 options now .
@Berry_DE_HAAS As what should I configure the third option?
@ricki-z I have a sds011, BME280 and a INMP444 microfoon sensor connected to the board
@Berry_DE_HAAS I’ve added the SDS011.
Hello, I accidentally deleted Sensor ID: 8814447. How do I add it again?
Hello @Przemek , I’ve restored the device registration.
I removed my sensor from my devices list and now find that I can’t add it back. The message I receive states that the sensor ID is already registered.
@Nenad_Grujicic I’ve restored the device registration.
Thank you! Is it possible to add BME280 to ID: 15652473 as well? Thank you for your help and support
I’ve the same problem but unfortunatelly I deleted it, so if I try to registrate I got the same “the sensore is already registered”
Please reset my sensor to register it again ID: esp8266-8319863.
Thanks,
Nandor Kiss
Is it possible to resolve my sensor esp8266-8319863.
Thanks,
Nandor
