I have a fairly standard setup … my ESP8266 sits on an Airrohr circuit board and I have the SDS, a BME and a DNMS attached to it.
All worked fine until ~a month ago. Suddenly the SDS does no longer provide data as it is apparently not recognized by the ESP.
*ID: 100xxxxx (e8db8499c4a4)*
*Firmware: NRZ-2020-133/DE (Nov 29 2020)*
*Übersicht » Debug Level*
*airRohr: NRZ-2020-133/DE*
*mounting FS...*
*opened config file...*
*parsed json...*
*output debug text to displays...*
*Connecting to <<myWIFI>>*
*....SNTP synced: Wed Aug 18 09:28:42 2021*
*twoStageOTAUpdate*
*WiFi connected, IP is: 192.168.178.43*
*Starting Webserver... 192.168.178.43*
*ChipId: 100xxxxx*
*MAC Id: e8db8499c4a4*
*Read SDS...: *
*Stopping SDS011...*
*Read BMxE280...*
*Trying BMx280 sensor on 76 ... found*
*Read DNMS...*
*Trying DNMS sensor on 0x55H ... found: DNM*
Of course, I already restarted multiple times (soft and hard reset), validated cables etc … Any further suggestions?
Did you check all the connections? Silly to say, but I had a sensor disappear once, and it appeared to be the cables weren’t connected properly. I hope you will fix it soon!
As of today, my sensor is also no longer providing data. It has done its job for two months without any problems. I now have only dashes in the fine dust values. Have already performed a reboot.
Next weekend I’ll open the box and look for possible failures. Wifi signal is around -61 dBm. PSU is a MeanWell HDR-15-5. Webinterface and BME280 are still working. So I think something with the SDS011 is wrong.
I mounted the sensor and other components on din-rail in a big electronic box. A silicone hose ~30-40cm goes outside the box. The Box has near the SDS011 a hole protected with mesh to let the air from the fan goes outside the box. Next weekend I’ll post a picture. Maybe someone can see where the problem is
My installation is hard wired. It’s not easy to power cycle. That’s the reason I only tried to reboot. Have to install a sonoff or Shelly for next time
