### PROBLEM DESCRIPTION
I'm using a self compiled version of Tasmota (current H…EAD), which includes only the sensors SDS011, DHT22, BMP280 and BH1750. After the cold start of Tasmota all sensors deliver values. After about 6 days the SDS011 does not deliver any data anymore. Only a powercycle brings the SDS011 back to life.
As hardware I use a Wemos D1 Mini, which is powered by a USB power supply. The SDS011 is directly connected to the 5V from the power supply.
### REQUESTED INFORMATION
_Make sure your have performed every step and checked the applicable boxes before submitting your issue. Thank you!_
- [ ] Read the [Contributing Guide and Policy](https://github.com/arendst/Tasmota/blob/development/CONTRIBUTING.md) and [the Code of Conduct](https://github.com/arendst/Tasmota/blob/development/CODE_OF_CONDUCT.md)
- [x] Searched the problem in [issues](https://github.com/arendst/Tasmota/issues)
- [x] Searched the problem in the [docs](https://tasmota.github.io/docs/FAQ)
- [ ] Searched the problem in the [forum](https://groups.google.com/d/forum/sonoffusers)
- [ ] Searched the problem in the [chat](https://discord.gg/Ks2Kzd4)
- [x] Device used (e.g., Sonoff Basic): Wemos D1 Mini
- [ ] Tasmota binary firmware version number used: HEAD
- [ ] Pre-compiled
- [x] Self-compiled
- [x] IDE / Compiler used: Platform-IO
- [ ] Flashing tools used: _____
- [ ] Provide the output of command: `Backlog Template; Module; GPIO 255`:
Configuration output here:
17:31:16 MQT: stat/esp24/RESULT = {"NAME":"Wemos D1 Mini","GPIO":[1,1,320,1,1,1,0,0,1,1,1,1,1,1],"FLAG":0,"BASE":18}
17:31:17 MQT: stat/esp24/RESULT = {"Module":{"0":"Wemos D1 Mini"}}
17:31:17 MQT: stat/esp24/RESULT = {"GPIO0":{"0":"None"},"GPIO1":{"1728":"SDS0X1 Tx"},"GPIO2":{"320":"Led_i1"},"GPIO3":{"1760":"SDS0X1 Rx"},"GPIO4":{"640":"I2C SDA"},"GPIO5":{"608":"I2C SCL"},"GPIO9":{"0":"None"},"GPIO10":{"0":"None"},"GPIO12":{"0":"None"},"GPIO13":{"1216":"AM2301"},"GPIO14":{"0":"None"},"GPIO15":{"0":"None"},"GPIO16":{"0":"None"},"GPIO17":{"0":"None"}}
- [ ] If using rules, provide the output of this command: `Backlog Rule1; Rule2; Rule3`:
Rules output here:
- [ ] Provide the output of this command: `Status 0`:
STATUS 0 output here:
17:32:27 MQT: stat/esp24/STATUS = {"Status":{"Module":0,"DeviceName":"esp24","FriendlyName":["esp24"],"Topic":"esp24","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}}
17:32:27 MQT: stat/esp24/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota-DE.bin","RestartReason":"External System","Uptime":"7T01:27:28","StartupUTC":"2020-10-29T15:04:59","Sleep":200,"CfgHolder":4617,"BootCount":16,"BCResetTime":"2020-03-23T15:46:52","SaveCount":41,"SaveAddress":"3F7000"}}
17:32:27 MQT: stat/esp24/STATUS2 = {"StatusFWR":{"Version":"9.0.0.2(eku-sensor)","BuildDateTime":"2020.10.19 15:39:14","Boot":31,"Core":"2_7_4_3","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"418/699"}}
17:32:27 MQT: stat/esp24/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":1,"LogHost":"+++deleted","LogPort":514,"SSId":["+++deleted+++],"TelePeriod":300,"Resolution":"518180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00006000","00000000"]}}
17:32:27 MQT: stat/esp24/STATUS4 = {"StatusMEM":{"ProgramSize":417,"Free":2652,"Heap":26,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":3,"Features":["00000407","00000484","04000001","00801482","00000000","00000000","00400000","00000000"],"Drivers":"1,2","Sensors":"2,6,9,10,20,76"}}
17:32:27 MQT: stat/esp24/STATUS5 = { +++deleted+++}
17:32:27 MQT: stat/esp24/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.22.1","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_22B2EF","MqttUser":"DVES_USER","MqttCount":89,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
17:32:27 MQT: stat/esp24/STATUS7 = {"StatusTIM":{"UTC":"2020-11-05T16:32:27","Local":"2020-11-05T17:32:27","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":99}}
17:32:27 MQT: stat/esp24/STATUS10 = {"StatusSNS":{"Time":"2020-11-05T17:32:27","AM2301":{"Temperature":9.2,"Humidity":79.2,"DewPoint":5.8},"BMP280":{"Temperature":11.8,"Pressure":970,"SeaPressure":1034},"BH1750":{"Illuminance":0},"SDS0X1":{"PM2.5":6.8,"PM10":20.2},"PressureUnit":"hPa","TempUnit":"C"}}
17:32:27 MQT: stat/esp24/STATUS11 = {"StatusSTS":
- [ ] Provide the output of the Console log output when you experience your issue; if applicable:
_(Please use_ `weblog 4` _for more debug information)_
Console output here:
17:37:03 MQT: tele/esp24/SENSOR = {"Time":"2020-11-05T17:37:03","AM2301":{"Temperature":9.1,"Humidity":79.9,"DewPoint":5.8},"BMP280":{"Temperature":11.7,"Pressure":971,"SeaPressure":1034},"BH1750":{"Illuminance":0},"SDS0X1":{"PM2.5":6.8,"PM10":20.2},"PressureUnit":"hPa","TempUnit":"C"}
### TO REPRODUCE
Just run the system for several days.
### EXPECTED BEHAVIOUR
Always receive data for the SDS011.
### SCREENSHOTS
none
### ADDITIONAL CONTEXT
none
**(Please, remember to close the issue when the problem has been addressed)**
