I would like to export all my sensor data to influx db. Can anyone help me with the api configuartion below
Thanks in advance
Thanks in advance
You would need to have acces to a (remote) server. Have it setup to your own liking with influxDB and than you can configure the setup of your sensor to send data correctly to the influx database.
Hello Jan,
Thanks for the reply. I appreciate your time. Below is the configuration for post method to write into influxdb 2, i am using basic authentication
I don’t see any data in influx db on the vm. Does the influxdb2 supports basic auth?
I have tried from postman too, it doesn’t work with basic auth.
