Difference between Nettigo and Sensor.Community kits
@Paolo Assembly was very easy; it works perfectly since then.
The only issue I had with it is the fact that the temperature measurements are performed twice, because there are two T sensors, and there is a 1°C difference between them.
I consider this comes from the fact the second T measurement is performed inside the box, so it get hotter because of the electronics dissipation.
I discussed the issue here on the forum.
