Working with sps30 and esp32 on micropython
Hello!
I am trying to make the sps30 work with the esp32 but with micropython. I found a library online but it tested using raspberri pi: sps30/sps30.py at master · feyzikesim/sps30 · GitHub so I tried converting it to a usable code for esp32.
I am having problems writing on the i2c bus For example, on the original code:
SPS_ADDR = 0x69
R_ARTICLE_CD = [0xD0, 0x25]
def read_article_code(self):
result =[]
article_code =[]
    write = i2c_msg.write(self.SPS_ADDR, self.R_ARTICLE_CD)
    self.bus.i2c_rdwr(write)
    read = i2c_msg.read(self.SPS_ADDR, 48)
    self.bus.i2c_rdwr(read)
    for i in range(read.len):
        result.append(bytes_to_int(read.buf[i]))
    if checkCRC(result):
        for i in range (2, len(result), 3):
            article_code.append(chr(result[i-2]))
            article_code.append(chr(result[i-1]))
        return str("".join(article_code))
    else:
        return self.ARTICLE_CODE_ERROR
The code I was able to do was:
SPS_ADDR = b’\x69’
R_ARTICLE_CD = bytearray([0xD0, 0x25])
    result = []
    article_code = []
    write = bytearray(self.R_ARTICLE_CD)
    self.i2c.writeto(self.SPS_ADDR, write)
    time.sleep(0.1)
    read = bytearray(48)
    self.i2c.readfrom_into(self.SPS_ADDR, read)
    else:
The terminal outputs TypeError: can’t convert bytes to int on the self.i2c.writeto(self.SPS_ADDR, write) line. I’m guessing this would happen on the read part also.
I am hoping that maybe someone here could help me? Thanks!
Byte is int8 or uint8
Int is int16 or uint16
I think it is the issue.
Here you convert : result.append(bytes_to_int(read.buf[i]))
It seems that I2C want some int array and not a byte array.
do i conver the bytes to int then convert it back when i need it?
I think it is what micropython expects according to the error message.
