Rather than putting “airrohr” in a tube, I took in a box.
Sensors are working fine. check out Umweltdaten - h-reiners.de
Here, having wind sensors would by fine. Any economic solution doing it with the esp module ?
No problem if the air can enter and exhaust easily.
I have already thought of wind sensors. The beta firmware can run on esp32. It could ba added.
Do you have an example and a datasheet?
I’ve just uploaded a pdf showing the difference in humid/temp readings depending on location of the sensor in the enclosure. Be sure to not mount the sensors on PCB, and locate the BME280 as close to the outside ambient air as possible!
