Where is the Server Data
It was my understanding that every data point was saved on servers in Germany. The data was accessed by: https://api-rrd.madavi.de/csvfiles.php?sensor=esp8266-1004961 (where 1004961 is the chip identification). It seems that this data is no longer accessible. Is this a temporary glitch, has the URL changed or is this data no longer available?
I use
https://api-rrd.madavi.de:3000/grafana/d/GUaL5aZMz/pm-sensors?orgId=1&var-chipID=esp8266-1004961&theme=dark
Hey fredvduin,
That URL which you posted is for the graphical representation of the data. Previously, we could use the URL in my earlier post to see every measurement for all historical data, going back years in CSV files.
@Charlie_Pierce this should work again. It was only a wrong path after a script change …
Apologies for the off-topic question. How do I find out the sensor ID for a sensor that I see on the map? I need the ID of this one. When I click on it, it shows Sensor #19776 but the ID in the links shared above looks different.
Or alternatively, how can I download the data from 19776?
You can download the data of a specific sensor on the map at https://archive.sensor.community/.
The mapping chipID (links above) to map ID is only known to the owner of the sensor. The chipID is a hardware ID (part of the wifi MAC address). So knowing the approximate location would make it possible to search for a sensor with a wifi scanner.
Hey Ricki-z,
How can I access the csv files now. https://api-rrd.madavi.de/csvfiles.php?sensor=esp8266-1004961 does not seem to be working.
The link should work again. The server just needed a restart …
Thanks for all of your help.
Hi Rajko,
The devices.sensor.community isn’t working anymore. Is there any connection with the sever restart?
@luft.koeln this is running on another server, but both also serve requests under data.sensor.community. It seems like single users are sending very strange requests, that don’t close the connection correctly or leave them open for a long time. So more and more processes are running.
Devices.sensor.community should now be available again.
