Presumably I can point the airRohr firmware flashing App to this beta build having downloaded it?
I cant enable auto update because I cant make an AP using latest.bin on this WEMOS d1 Pro Mini. I can knock up my own sketch and get an AP which is very frustrating.
Not sure about airrohr app being able to flash beta releases. But you can download and flash the firmware with other tools. On Mac I use nodemcu-pyflasher. There is a windows executable, too. (link)
Note, I am by no means an expert! There are much more capable people on this forum and hopefully correct me in case I am giving bad advice.
Curiosity question it possible to do ones own build?
I would have switched the I2C to D5/D7 and turned off auto update until such time as I had a working solution on D3/D4.
Powered from my Laptop usb port. That is how I see the serial monitor message.
I flash with airRohr -firmware-flasher-0.3.2-Windows.amd64.exe
Never been a problem before. It appears to be this board and it’s the only board I have where everything else is working.
I can flash it using Arduino IDE and it does the WiFi scan example no problem.
Final update guys and for any others who have followed this post.
I looked to purchase a WEMOS Mino Pro from Nettigo but no delivery option for UK. Brexit issue I assume.
So I bought a LOLIN Mini Pro from Hobby Electronics. I flashed it with the latest_en.bin and it all worked as expected and is now publishing results.
It just shows how important it is to buy reputable MCU’s although I do wish you could select one with the external antenna enabled by default to avoid that fiddley job. Done now.
Many thanks for you help.
Hello…Same issue with HW serial (with impaired serial logging) association and SW serial association (for illustration GPIO14&GPIO12). As you’ll see such boot circles can be replicated only if S8 gadget was enacted (you’ll be able discover it’s SN). Moreover this boot circles will going up on the off chance that gadget was detached (no serial transmission from sensor). It’s see like a few ESPEasy FW trigger was strangely changed at that point S8 was included in dynamic state and a few information was gotten.
