Hi, I have a sensor that is not appearing on the map anymore, what pc software would enable me to check if the sensor is working on a win 10 pc via the usb connection
The easiest way is to install the Arduino IDE. It should open the ports and you should be able to the the info in the serial monitor at 9600 bauds.
https://docs.arduino.cc/software/ide-v2/tutorials/getting-started/ide-v2-downloading-and-installing
Check here for the driver for the ports:
https://sensor.community/en/sensors/airrohr/
Okay thanks ill give it a try and get back to you
Thanks for the info by connecting to a pc with the Arduino software I have managed to get the sensor back on the network
