is there already a solution for just pushing the data from influx to your servers? we have also a lot of historical data, would it be also possible to send that to you?
What kind of data do you have ?
Which sensor(s)?
Which time span ?
i have a SDS011 with a bme280, i fed them directly into my influxdb, i started logging 2023-02-15, still doing so. these are the fields i have:
time BME280_humidity BME280_pressure BME280_temperature SDS_P1 SDS_P2 interval max_micro min_micro node samples signal
For collecting the data from the beginning I donāt know.
But for current data, you just have to forward from influx db to SC API with POST requests:
Prepare everything for the SC API and also the Madavi API (2 requests) and then I will help you to finalize the requests because there is a small thing to take care of.
hmmm, thank you very much. i found this page in english. i was hoping someone already built such a forwarder tool. but i guess, i have to do it then. will take some time, being swamped with other stuff. but i will have come back to this.
These are normal POST requests with headers and data as json.
sure, sounds easy enough, i just hoped someone already had this done.
A lot of people are doing it currently. Actually I found everything in my notes:
SC server:
url: https://api.sensor.community/v1/push-sensor-data/
method: POST
content_type: āapplication/jsonā
headers:
X-Pin: 1
X-Sensor: Board ID
"software_version": "<WHAT YOU WANT>",
"sensordatavalues":[
{"value_type":"P1","value":"<PM10>"},
{"value_type":"P2","value":"<PM2.5>"}
method: POST
headers:
X-Pin: 11
X-Sensor: Board ID
{"value_type":"temperature","value":"<TEMP>"},
{"value_type":"pressure","value":"<PRESS>"},
{"value_type":"humidity","value":"<HUMI>"}
Madavi server:
url: https://api-rrd.madavi.de/data.php
method: POST
headers:
X-Pin: 1
X-Sensor: Board ID
{"value_type":"SDS_P1","value":"<PM10>"},
{"value_type":"SDS_P2","value":"<PM2.5>"}
method: POST
headers:
X-Pin: 11
X-Sensor: Board ID
{"value_type":"BME280_temperature","value":"<TEMP>"},
{"value_type":"BME280_pressure","value":"<PRESS>"},
{"value_type":"BME280_humidity","value":"<HUMI>"}
The problem is the Board ID.
There is no InfluxDB-ā¦
@ricki-z An idea ?
thanks for sharing your awesome notes! <3
why cannot i use the original board id from the device that dumps to my influx?
Yes you can! Is it an esp ?
yes. padding to 20 chars.
three questions:
- the āvaluesā in the json payload, do they have to be strings, or can they be floats?
- the software_version, donāt really know, is N/A, null, or something else acceptable?
- the boardid, would that be ''esp8266-1234567" or only the numbered part ā1234567ā?
apart from these details i think i have a first draft that might work (the boardid needs to be set correctly, and the request.posts uncommented, but otherwise iād give it a try):
#!/usr/bin/env python
from influxdb import InfluxDBClient
import time, requests, datetime
boardid = 'esp8266-1234567'
lastseen=None
def push(d):
global lastseen
# [{'time': '2025-03-07T02:00:54.099740Z', 'BME280_humidity': 73.43, 'BME280_pressure': 101565.53, 'BME280_temperature': 6.63, 'SDS_P1': 13.2, 'SDS_P2': 8.0, 'interval': 10000.0, 'max_micro': 1137.0, 'min_micro': 23.0, 'node': 'esp8266-1234567', 'samples': 416113.0, 'signal': -93.0}]
ts = datetime.datetime.fromisoformat(d['time'][:-1]).replace(tzinfo=datetime.timezone.utc)
if ts == lastseen: return
now = datetime.datetime.now(datetime.timezone.utc)
if(ts<now-datetime.timedelta(seconds=15)):
print("last record is too old:", now-ts)
return
print(d)
lastseen = ts
data = { "software_version": "<WHAT YOU WANT>",
{"value_type":"P1","value":d['SDS_P1']},
{"value_type":"P2","value":d['SDS_P2']}]}
headers = { 'X-Pin': 1, 'X-Sensor': boardid }
#requests.post('https://api.sensor.community/v1/push-sensor-data/', json=data, headers = headers)
{"value_type":"SDS_P1","value":d['SDS_P1']},
{"value_type":"SDS_P2","value":d['SDS_P1']}]}
#requests.post('https://api-rrd.madavi.de/data.php', json=data, headers=headers)
headers = { 'X-Pin': 11, 'X-Sensor': boardid }
{"value_type":"temperature","value":d['BME280_temperature']},
{"value_type":"pressure","value":d['BME280_pressure']},
{"value_type":"humidity","value":d['BME280_humidity']}]}
{"value_type":"BME280_temperature","value":d['BME280_temperature']},
{"value_type":"BME280_pressure","value":d['BME280_pressure']},
{"value_type":"BME280_humidity","value":d['BME280_humidity']}]}
# Create an InfluxDB client
client = InfluxDBClient(database="sensors")
# Monitor new values in a loop
try:
while True:
rs = client.query('select * from feinstaub ORDER BY time DESC LIMIT 1')
last = list(rs.get_points())[0]
push(last)
time.sleep(10) # Adjust the sleep time as needed
except KeyboardInterrupt:
print("Monitoring stopped.")
# Close the client
client.close()
String mit . in āā
You can put what you want
@ricki-z I canāt rememberā¦
looks like it is āeps8266-1234567ā looking at the source:
./airrohr-firmware/airrohr-firmware.ino: http.addHeader(F("X-Sensor"), String(F(SENSOR_BASENAME)) + esp_chipid);
so got this running, and on api-rrd.madavi i see data being processed.
thank you for all the help. if anyone needs it, this is my final script
import time, requests, datetime, json
lastseen=None
def push(d):
global lastseen
if d['node'] != boardid: return
return
print(d)
lastseen = ts
data = { "software_version": "null",
{"value_type":"P1","value":str(d['SDS_P1'])},
{"value_type":"P2","value":str(d['SDS_P2'])}]}
headers = { 'X-Pin': "1", 'X-Sensor': boardid }
#print(json.dumps(data), json.dumps(headers))
{"value_type":"SDS_P1","value":str(d['SDS_P1'])},
{"value_type":"SDS_P2","value":str(d['SDS_P1'])}]}
headers = { 'X-Pin': "11", 'X-Sensor': boardid }
{"value_type":"temperature","value":str(d['BME280_temperature'])},
{"value_type":"pressure","value":str(d['BME280_pressure'])},
{"value_type":"humidity","value":str(d['BME280_humidity'])}]}
{"value_type":"BME280_temperature","value":str(d['BME280_temperature'])},
{"value_type":"BME280_pressure","value":str(d['BME280_pressure'])},
{"value_type":"BME280_humidity","value":str(d['BME280_humidity'])}]}
try:
while True:
push(last)
time.sleep(4) # Adjust the sleep time as needed
# Close the client
client.close()
