Who knows how to solve the issue mentioned in github?
I have two airrohre and both are not synced with ntp. All computers in the network can connect and are synced. What can I do? I’ve done restarts but it doesn’t help. Because of the missing time - both have the date of 1.1.1970 - they can’t upload to madavi and the other API’s. Last upload was at the 16th of December.
Actually I updated my router, a Turris Omnia, about that time. The problem could be the router as well.
Is there a way to check if the airrohr software tries to contact the ntp servers? I can sucessfully ping 0.pool.ntp.org from my laptop.
I checked the router and it is not acting as a NTP server. Just to try I configured the router acting as an NTP server than, restarted it and one sensor but it didn’t change anything.
Firmware is NRZ-2020-133. Here the routers NTP config as screenshot: NTP-Omnia|519x473
I have rolled back the system on my router to an earlier state and now both sensors get ntp time again. The NTP settings are exactly the same. I still don’t know what was the problem at the moment.
I would suggest to close this topic, as it is not related with the airrohr software.
Thank you for your help!
