Hi!
I was wondering if it would be possible to have the possibility to connect to temperature sensors DS18B20 on the nodemcu V3 firmware.
Best regards,
Hi!
Best regards,
@irukard How it works ?
OneWire. Every sensor has unique address.
I tried but I didn’t receive the data from the second temperature sensor in the firmware I use for the luftdaten air sensor nodemcu v3
Should this work, did I make a mistake?
Regards Arjan
I don’t think multiple sensors are supported by firmware.
You will have to modify the firmware to set the second adress or to switch between the 2 addresses.
Hi PJG,
Question would be: how ?
