Tried to replicated existing systems but failed
I am sorry. I attempted to replicate some sensors that I registered some time ago but I have made a real mess of things in my device settings.
My 2 existing, working sensors are #35893 and #47022.
I misread the prompts while registering my 3rd sensor and tried to recover by re-registering it 2 more times, using different values. I was hoping that I could then delete the others. But I’m stuck, as all 3 new sensors (#54131, #54132, #54133) fail. I did not want to risk deleting something and then being unable to gain access.
On my system I continually get:
2024-11-13 15:10:44.354 WARNING Sensor.Community Error. PM: Forbidden, Climate: Forbidden
2024-11-13 15:10:44.355 WARNING Sensor.Community Response: Failed
Richard_Slusser
Welcome back!
I can’t understand what you did. How could you choose the sensor ID yourself ?
@ricki-z
Okay, I deleted the 3 bogus devices (I was using the wrong serial number. Duh.)
I added the device using the correct serial number…but this does not work.
I still get these:
2024-11-14 16:10:44.354 WARNING Sensor.Community Error. PM: Forbidden, Climate: Forbidden
2024-11-14 16:10:44.355 WARNING Sensor.Community Response: Failed
Well, I’m not sure what happened, but it started working.
Thank you if you did something.
If not, then it must be something I did here as I was trying to match this system to the other 2.
Either way, thanks for reading.
