I noticed that my sensors, running on an esp8266, has a lot of network calls to 1.pool.npt.org. This is a time server and I don’t know why so many calls are needed. I could block it (using pihole) but as this is a general time server that will probably lead to issues with other devices. Is there a reason for this many calls? And, if not, what could be done to solve this?
Normally the sensor should call the ntp servers once per hour. This is needed to get a correct time for HTTPS certificate checks.
Could you please check the device internal status page that the sensor can connect to the ntp servers.
That sounds logical but is a bit more difficult than I thought. It is running on my guest network (not some kind of IoT network) but I cannot connect to it directly, also not when I log in onto the same guest network.
I’ll work on it and let you know later. Perhaps this is the time to setup an IoT network which I planned doing for some time now.
Yes, this is a feature for guest networks that the guests are separated against each other.
On some systems this can be deactivated (temporarily).
I know this for the AVM FritzBox that they had forbidden access to the NTP servers for the guest network. Only mail and http/https were possible…
