Hi there,
looks like I am too stupid to bring the system into local WIFI (called “chanti” here).
What can I see:
System always ends in access point mode.
system interface is always in english, even if german is selected
What did I try:
I flashed with airRohr-firmware-flasher-0.3.2-Windows_amd64 and 0.3.4 as well.
used different binaries for flashing in en and de (in my case).
tried different WIFI networks. all support 5 GHz and 2,4 GHz, SSID and password are correct
played with distance to WIFI router…
used putty to get logs!
Restart.
▒▒airRohr: NRZ-2020-133/EN
mounting FS...
opened config file...
parsed json...
output debug text to displays...
Connecting to chanti
Starting WiFiManager
AP ID:
Password:
scan for wifi networks...
AP Password is:
Starting Webserver... (IP unset)
So it looks like system tries to connect to WIFI but somehow fails. I can’t see the reason. (even increasing debug level to values bigger 3 does not extend info)
Removing sensor connections (temperature and particle) does not change behaviour (I did not expect but at least it was a try)
giving a WIFI password known as wrong does not lead to any change in putty logs…
create guest network @ 2,4 GHz (named GST) without any access restriction or password. selected this network in user interface of NodeMCU but the result is the same
Restart.
▒▒airRohr: NRZ-2020-133/DE
mounting FS...
parsed json...
Connecting to GST
AP ID:
Password:
AP Password is:
I let it run the whole night with several resets in between. Since there was no success I reflashed system with airRohr-firmware-flasher-0.3.4-Windows_amd64_BETA used latest_de.bin → airRohr: NRZ-2020-133/DE
Additionally I activated guest network @ 2,4 GHz for a while to “stabilize” (even if this would not make any difference in my understanding)
Fortunately I am a step further now:
mounting FS...
parsed json...
Connecting to GST
....SNTP synced: Thu Mar 9 19:02:45 2023
twoStageOTAUpdate
WiFi connected, IP is: 192.168.1.126
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (28):
epc1=0x4000bdc8 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd30 end: 3fffffc0 offset: 0190
3ffffec0: 00000003 00000000 3ffef4b0 3fffff10
3ffffed0: 3fffff48 00000050 3fffff10 3ffef27f
3ffffee0: 3ffe8939 3ffe8934 3ffef4b0 40218194
3ffffef0: 3ffe892b 3ffe8930 3ffef4b0 4020ab58
3fffff00: 00000040 00000000 feefeffe feefeffe
3fffff10: 70747400 000d0000 80201b44 402013cc
3fffff20: feefeffe feefeffe feefeffe feefeffe
3fffff30: feefeffe feefeffe feefeffe feefeffe
3fffff40: feefeffe feefeffe 00706300 7e01a8c0
3fffff50: 80efeffe 00000000 00000000 feefeffe
3fffff60: feefeffe feefeffe feefeffe feefeffe
3fffff70: feefeffe 01004544 feef010d feefeffe
3fffff80: 3ffeea31 feefeffe feefeffe feefeffe
3fffff90: feefeffe feefeffe feefeffe 3ffef6a8
3fffffa0: 3fffdad0 00000000 3ffef668 40223240
3fffffb0: feefeffe feefeffe 3ffe8690 401006c9
<<<stack<<<
Now I need to figure out what causes this exception...
In fact it is. So I went into cellar, there a wifi router with older standard is available. I configured it to “mixed 802.11 g/n”. Unfortunately this change did not lead to any improvement!
Hi @Danny
You wrote “…giving a WIFI password known as wrong does not lead to any change in putty logs…”. I know it sounds stupid, but you might have put in a wrong password all the time. Maybe a change on the router? Just double check. I had this kind of situations, when I was 100% sure about a password and tried everything, before checking the password on the router again.
Comment #5 would support that thought. You’ve tried a new guest access point and that worked, right? At least it synced SNTP and says WiFi connected, IP is: 192.168.1.126. Is the WiFi problem solved?
As I even do not trust myself I copy-pasted it into Notepad++ from webinterface of router…
The issue is solved since I changed the WIFI (the one in cellar is using a different WIFI router). I still can’t access WIFI with my newer WIFI 6 router. This does not hurt me since the sensor is working now but from a technical perspective this is not satifying
