Sensor stopped sending data
My sensor stopped sending data, the network environment is not changed.
I have unplugged the inverter, no result.
I have tested the inverter, works.
The power outlet is OK
Any suggestions?
Guido
Welcome on board.
What is an inverter ?
Can you read the USB log of the sensor ? You can use the monitor of the Arduino IDE.
Can you see the Sensor as an Access Point ?
Is the sensor in AP mode?
I use discovery tab for detecting sensors
https://firmware.sensor.community/airrohr/flashing-tool/
If no sensor visible.
Connect sensor(NodeMCU) on a USB port PC/Laptop (windows)
Restart Flasher tool
Board is connected to …(this case COM3)
Download Putty (Free)
Open (Button) the terminal
Press Reset (RST) button on NodeMCU
