Hi everyone,
How come only one sensor is measuring although they’re connected to the same NodeMCU?
Configuration issue ?
Câble disconnected?
Check the Sensor 2 in both the config Interfaces. Everything on thé webpage
Hi, I have the same Problem. these senors don’t have date on map, but they have in interface. thank you for your antwort. I have 5 sensors in same place, just 3 von their are in map.
Can you give “Device status” (menu sensor)
Is the NTP reachable
Example:
Doe you use fixed ip?
