Sensor.community KIT from NETTIGO with HECA KIT
Hi everyone. I bought a Sensor.community kit from Nettigo, but during the first rain, the PM readings shot through the roof. So, I decided to buy the HECA kit as well. Am I correct in understanding that I don’t need to connect it to the NodeMCU? I just need to power the HECA unit and use a 2A power supply? Will the HECA board automatically activate the heating when humidity is high? Thanks for the clarification.
I’m not sure, but have you seen this instruction from Nettigo about the HECA: NAM HECA 0.3.3 - soldering | Nettigo Docs
Perhaps that will provide you with an answer. It comes from the Nettigo Air Monitor | Nettigo Docs
Hey, it would help if you provide the exact name of the sensor you bought and the HECA unit you purchased and how you connected them. I bought this sensor: https://nettigo.pl/products/nettigo-air-monitor-0-3-zlutowany-kompletny-zlutowany-zestaw-wersja-pro-z-zewnetrzna-antena and yes the HECA is automatically activated if humidity exceeds 70%.
