Sen5x and scd30 nox voc co2 no2 not recognised value_type
Hi is anyone succesfully uploaded these values ?
i trying but got that nox, NOX, voc, VOC, co2 and CO2 is not correct.
Output from my domoticz is
2025-02-07 00:45:00.493 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: SEN5x payload: {“sensordatavalues”:[{“value”:“20.2”,“value_type”:“P0”},{“value”:“22.0”,“value_type”:“P2”},{“value”:“23.1”,“value_type”:“P1”},{“value”:“1.0”,“value_type”:“nox”},{“value”:“52.0”,“value_type”:“voc”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:00.493 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: SCD30 payload: {“sensordatavalues”:[{“value”:“427.0”,“value_type”:“co2”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:00.493 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: NO2 payload: {“sensordatavalues”:[{“value”:“88.49”,“value_type”:“NO2”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:00.493 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 1” -H “X-Sensor: esp32-4522171” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“20.2”,“value_type”:“P0”},{“value”:“22.0”,“value_type”:“P2”},{“value”:“23.1”,“value_type”:“P1”},{“value”:“1.0”,“value_type”:“nox”},{“value”:“52.0”,“value_type”:“voc”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:00.652 InfluxLink: value Percentage,idx=940,name=Apollo-AIR-1-cdf7b4-(PM2.5-Average) value=23.251999
2025-02-07 00:45:00.979 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensordatavalues”:[{},{},{},{“value_type”:[“"nox" is not a valid choice.”]},{“value_type”:[“"voc" is not a valid choice.”]}]}
2025-02-07 00:45:00.979 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 11” -H “X-Sensor: esp32-4522172” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“427.0”,“value_type”:“co2”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:01.157 InfluxLink: value Percentage,idx=935,name=Apollo-AIR-1-cdf7b4-(PM2.5-diff->-50) value=0.000000
2025-02-07 00:45:01.158 InfluxLink: value Percentage,idx=930,name=Apollo-AIR-1-cdf7b4-(PM2.5-Last-Good) value=23.251999
2025-02-07 00:45:01.415 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensordatavalues”:[{“value_type”:[“"co2" is not a valid choice.”]}]}
2025-02-07 00:45:01.415 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 15” -H “X-Sensor: esp32-4522173” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“88.49”,“value_type”:“NO2”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:01.847 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensordatavalues”:[{“value_type”:[“"NO2" is not a valid choice.”]}]}
2025-02-07 00:45:01.848 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Finished sending sensor data
2025-02-07 00:45:01.848 dzVents: SensorCommunityUpload: ------ Finished Script #1
2025-02-07 00:45:01.848 dzVents: SensorCommunityUpload: ------ Start internal script: Script #2:, trigger: “every 1 minutes”
2025-02-07 00:45:01.848 dzVents: SensorCommunityUpload: SensorCommunityUpload: Preparing to push sensor data to Sensor.Community
2025-02-07 00:45:01.849 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: SEN5x payload: {“sensordatavalues”:[{“value”:“22.0”,“value_type”:“P2”},{“value”:“23.1”,“value_type”:“P1”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:01.849 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: SCD30 payload: {“sensordatavalues”:[{“value”:“427.0”,“value_type”:“CO2”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:01.849 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: NO2 payload: {“sensordatavalues”:[{“value”:“88.49”,“value_type”:“NO2”}],“software_version”:“enviro-plus 0.0.1”}
2025-02-07 00:45:01.849 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 1” -H “X-Sensor: esp32-4522171” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“22.0”,“value_type”:“P2”},{“value”:“23.1”,“value_type”:“P1”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:02.282 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensor”:92302,“timestamp”:“2025-02-06T23:45:00.917403”,“sensordatavalues”:[{“sensordata”:23774991868},{“sensordata”:23774991868}]}
2025-02-07 00:45:02.282 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 11” -H “X-Sensor: esp32-4522172” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“427.0”,“value_type”:“CO2”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:02.666 InfluxLink: value Percentage,idx=921,name=Apollo-AIR-1-cdf7b4-(PM10) value=23.3
2025-02-07 00:45:02.730 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensordatavalues”:[{“value_type”:[“"CO2" is not a valid choice.”]}]}
2025-02-07 00:45:02.731 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Executing curl command: curl -s -X POST -H “Content-Type: application/json” -H “X-PIN: 15” -H “X-Sensor: esp32-4522173” -H “cache-control: no-cache” -d ‘{“sensordatavalues”:[{“value”:“88.49”,“value_type”:“NO2”}],“software_version”:“enviro-plus 0.0.1”}’ “https://api.l ftdaten.info/v1/push-sensor-data/”
2025-02-07 00:45:03.172 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Curl output (first 1000 chars): {“sensordatavalues”:[{“value_type”:[“"NO2" is not a valid choice.”]}]}
2025-02-07 00:45:03.172 dzVents: Debug: SensorCommunityUpload: SensorCommunityUpload: Finished sending sensor data
2025-02-07 00:45:03.172 dzVents: SensorCommunityUpload: ------ Finished Script #2
I hope it is possible to upload any of these because such signals are very usefull in my smog prone valley. Thanks in advance.
The nox, voc, co2 and no2 values are not set up in the API. It is the reason why they are not recognized.
Maybe you can try to contact aircarto in Marseille, which has an API with no2 ans co2.
