Request to Rename Sensor Station
Station #98445”}
Hello Support Team,
I am the owner of the air quality sensor with ID #98445 on the Sensor.Community map.
I would like to kindly request to change the station name from “Sensor.Community #98445” to “BAAN HUAI THONG”. This is the name of the village where the sensor is installed.
Since I personally installed and operate this sensor, I would like the station name to correctly reflect the actual location. This will help people who view the data and organizations that use or retrieve the data to clearly understand where the measurements are coming from.
Thank you very much for your support and assistanc
there is no possibility to name the stations. All stations are only refered by number.
