No BME ?
You can use an USB to TTL dongle to test the SDS but it could be tricky.
You could also read the Logs of the sensor.
Do you have Arduino IDE in your Computer.
Are you sure câbles are well connected ? Did you triple check ?
If you mean “Debug level” when mentioning “Logs”, then I see endless repeating like : Time for Sending (ms): 56 ws: values … ws: root … ws: values …
*## Sending to madavi.de: * Succeeded - api-rrd.madavi.de Time for Sending (ms): 158
Yes, I have Arduino IDE, tried to connect ESP8266&SDS011 but yet didn´t find all libraries to succeed compilation…
TX → RX
RX → TX
irritates me - I soldered according sensor.community-schema:
TXD → D1
RXD → D2
thank you pjg - I had opportunity to test my circuit with another SDS011 which worked fine - seems I wrecked my SDS011 during installation.
I like the idea to see SDS011 at arduino-IDE-monitor …
