I would like to contribute to sensor community. Therefore I learned myself some python and looked into other scripts. But now I’m stuck at sending data to sensor.community. I must be missing something. Is somebody willing to help? My code:
Connects a SDS011 to a Raspberry Pi and send the results to sensor community
import time
import serial
import requests
import datetime
import json
Open serial connection to sensor
ser = serial.Serial(‘/dev/ttyUSB0’, baudrate=9600)
Your sensor’s coordinates
latitude = 12.34567890123
longitude = 1.23456789012
Format the coordinates as a string
location = str(latitude) + “,” + str(longitude)
while True:
# Put sensor in measurement mode (the 6th byte is 0x01 which means the sensor is in measuring mode)
ser.write(b’\xAA\xB4\x06\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xFF\xFF\x05\xAB’)
print(“Putting sensor in measurement mode”)
# Wait 60 seconds for sensor to warm up
print("Wait 1 minute for the sensor to warm up")
time.sleep(60)
# Read data from sensor
data = ser.read(10)
# Extract PM2.5 and PM10 values from data
pm25 = data[2] + data[3]/10
pm10 = data[4] + data[5]/10
# Print timestamp
now = datetime.datetime.now()
print("Timestamp: ", now)
# Print values on screen
print("PM2.5: ", pm25, "ug/m^3")
print("PM10: ", pm10, "ug/m^3")
# Put sensor in sleeping mode (the 6th byte is 0x00 which means the sensor is in sleeping mode)
ser.write(b'\xAA\xB4\x06\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xFF\xFF\x05\xAB')
print("Putting sensor in sleeping mode")
# Sense data to sensor community server
api_endpoint = "https://api.sensor.community.info/v1/push-sensor-data/"
data = {
"sensordatavalues": [
"value_type": "P1",
"value": pm10
"value_type": "P2",
"value": pm25
"location": location,
"sensor_id": 12345,
"timestamp": now.isoformat()
max_retries = 5
retries = 0
while retries < max_retries:
try:
# Your code that you want to retry
response = requests.post(api_endpoint, json=data)
# If the request is successful, break out of the loop
if response.status_code == 200:
print("Data sent successfully")
break
except Exception as e:
retries += 1
# Wait for 5 seconds before retrying
time.sleep(5)
continue
# Take reading every 4 minutes including sensor warm-up (as only measurements within 5 minutes are shown on the map)
print("Waiting 3 minutes for next reading cycle")
time.sleep(180)
Thanks. This and adding the # or id in the results part and adding the UID as authentication did the trick. My working code is now:
import time
import serial
import requests
import datetime
import json
UID = “raspi-1234”
while True:
print("Wait 1 minute for the sensor to warm up and turn on the fan")
time.sleep(60)
data = ser.read(10)
# Print timestamp
print("Putting sensor in sleeping mode which also turns off the fan")
api_endpoint = "https://api.sensor.community/v1/push-sensor-data/"
data = {
"id": 12345,
"value_type": "P1",
"value": pm10
"value_type": "P2",
"value": pm25
"sensor_id": 12345,
auth = {
"X-Sensor": UID
# Send data to API and print response
response = requests.post(api_endpoint, json=data, headers=auth)
print("Response:", response.text)
# Take reading every 10 minutes
print("Waiting 10 minutes (including warm-up) for next reading cycle")
time.sleep(540)
Solved it. I had to change the wake-up and or measurement command:
From
To
ser.write(b’\xAA\xB4\x06\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xFF\xFF\x06\xAB’)
Found the solution on Issue after sleep function · Issue #21 · ricki-z/SDS011 · GitHub
And lastly I had to change the extraction of the bytes and the calculation to get the correct PM values:
# Start reading data from the sensor
data = ser.read(10)
# Extract high and low bytes for PM2.5 and PM10 from data
pm25_low = data[2]
pm25_high = data[3]
pm10_low = data[4]
pm10_high = data[5]
# Calculate PM2.5 and PM10 values
pm25 = ((pm25_high * 256) + pm25_low) / 10
pm10 = ((pm10_high * 256) + pm10_low) / 10
