Hello forum members.
I am new here and love what you all are accomplishing.
I have electrical / electronics background and in my spare time I am working on a food forest .
Now I want to put 2 air quality and sound sensors in this forest.
Does anyone have experience with solarpower and 4G/LTE communication for these sensors.
What is the power consumption of these sensors ?
Thanks for your reply and info ibetsun.
Did you use a Sitcom NB IoT development board or did you made your own PCB with ESP and Simcom ?
do you have a schematic of your solution ?
I testd with Simcom devboard from AliExpress which there are plenty of. I am planning to develop a daughter board with Simcom module
The schematic is not ready yet. I suppose there will be some power management and a level shifter 1.8<>3.3V
As to the solar part, you can find some info there:
For powering air quality and sound sensors with 4G/LTE in a food forest, a small solar setup works well: most sensors use under 0.5 W, while a 4G modem averages 1–2 W (peaking higher during transmission). A 20–30 W solar panel with a 12V 7Ah battery and a compact charge controller is usually enough for continuous operation. To save power, configure the modem to transmit data at intervals (e.g., every 5–10 minutes) instead of streaming constantly, ensuring reliable performance even on cloudy days.
