Hi!
This is my second ESP8266 that stopped working in very short time (two-three months). I wonder if it is because of moisture? I don’t believe, that I purchased two faulty items…
Do you secure your microcomputers somehow from the moisture?
Of is there another reason?
Best regards
Marcin
Have you more information.
- Led flashing NodeMcu when reset
- Led flashing SDS011 and is fan rotating.
- Can you see some data on USB (with putty)
- Can you re-flash
- Is the NodeMcu clean or “rusty”
- Have you change USB adapter and cable
I will try to check it today and let you know.
Thank you, my fault. I brought it home, plugged in and I see the measurements. I have to redesign powering system
