Hardware config - devices.sensor.community is OK and my in sensor in map sensor works well.
Problem isw Grafana . Sensor DHT22 is wrong and SDS011 - No data
Can you help me how fix showing data in Grafana?
Thanks
The API for api-rrd.madavi.de needs a slightly different payload. All values are transmitted at once and the ‘value_type’ fields need a prefix. The X-Pin header isn’t needed. So for your transmission to api-rrd.madavi.de the message should be:
