Problem with 24h values
Since 2025-01-03 the timestamp on the sensor data delivered from https://data.sensor.community/static/v2/data.24h.json (average of all measurements per sensor of the 24 hours) is somehow locked to 2025-01-02, no data updates since that day.
Any clues?
Each month we do a backup of data saved in the last month. This needs some more resources for compressing and transfering nearly 500 GB of data. While this is done we deactivate the generation of the 24h values.
Normally this should be done in some hours. But the hosting provider seems to have a massive network problem at the moment. So this process needs longer than normal.
Thank you very much for your prompt reply!
We shall then wait and see what happens…
https://data.sensor.community/static/v2/data.24h.json has not been updated for several weeks now. Will it be available soon again?
