Part of map sensors comunmity with Home Matic Sensirion SPS30?
How can I register my Home Matic Sensirion SPS30 fine dust sensor with you and (if possible) become part of the community ?
I would like to provide the data and preferably using NodeRed.
Is there possibly a tutorial for the connection with NodeRed ?
From whom do I get the sensor ID ?
BR Quito96
Look at this page in the part “API sensor.commnunity”:
Try to make your system produce such POST request:
Content-Type: application/json
X-Pin: 1
X-Sensor: esp8266-12345678
   "software_version": "your_version",
  "sensordatavalues":[
    {"value_type":"P1","value":"66.04"},
    {"value_type":"P2","value":"53.32"}
Check the correct X-Pin and endpoint values for both the PM and THP sensors and both the SC and Madavi servers.
But don’t overload the API!
I read a bit about NodeRed. It should work easily.
Thank you for the information
I have just created the sensors and then
the ID in the accont. Now I can start to create the
Node Red components.
BR
You’re welcome!
Please share the code for NodeRed. It could interest others in the community.
For Madavi, I was told:
Madavi API needs a prefix for the value types. So if there is a BME280 sending data then i.e. ‘humidity’ weill become ‘BME280_humidity’. Other prefixes can be found in the firmware source code.
It is quite straight forward.
Which ID did you use ? The MAC as HEX byte of the Home Matic ? It has to be unique.
If your not using an ESP8266 or an ESP32, please ask tech@sensor.community for the good prefix. There are already a few in devices.sensor.community but nothing for NodeRed I think
yes gladly, as soon as I have successfully implemented it.
THX
here comes my solution to send data from my homematic rasberrymatic
System with HmIP-SFD (SPS30) Sensor via NodeRed.
  1. Register at https://devices.sensor.community
  2. Create a New Sensor (raspi, SPS30, BME280)
  3. Import Node Red Flow below (Adjustments required)
        "id": "168fbfbd.1b349",
        "type": "tab",
        "label": "Map-Sensor-Community ",
        "disabled": false,
        "info": "https://devices.sensor.community/sensors"
        "id": "8456d0bc.fbecd",
        "type": "comment",
        "z": "168fbfbd.1b349",
        "name": "Post homematic Data to https://api.sensor.community/v1/push-sensor-data/",
        "info": "",
        "x": 710,
        "y": 80,
        "wires": []
        "id": "28c280c5.420378",
        "type": "ccu-value",
        "name": "PM_2.5",
        "iface": "HmIP-RF",
        "channel": "00271D8993DCDA:1",
        "datapoint": "MASS_CONCENTRATION_PM_2_5",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "onType": "undefined",
        "ramp": 0,
        "rampType": "undefined",
        "working": false,
        "ccuConfig": "38263145.35ea0e",
        "topic": "${CCU}/${Interface}/${channel}/${datapoint}",
        "x": 140,
        "y": 140,
        "wires": [
                "6273c588.8e5af4"
        "id": "7b740d5b.d39214",
        "name": "PM_10",
        "iface": "HmIP-RF",
        "datapoint": "MASS_CONCENTRATION_PM_10",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 140,
        "y": 200,
        "wires": [
                "99377a93.bbeef"
        "id": "91343d53.60237",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 990,
        "y": 340,
        "wires": []
        "id": "bb44220e.9c8ae",
        "name": "PM_Temperature",
        "iface": "HmIP-RF",
        "channel": "00271D8993DCDA:1 Feinstaubsensor:1",
        "datapoint": "ACTUAL_TEMPERATURE",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 170,
        "y": 260,
        "wires": [
                "e00d9f12.d75c1"
        "id": "1f67f8c6.2f425f",
        "name": "PM_Humidity",
        "iface": "HmIP-RF",
        "datapoint": "HUMIDITY",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 160,
        "y": 320,
        "wires": [
                "1cb5402.8992d4"
        "id": "6273c588.8e5af4",
        "type": "change",
        "name": "set_topic_pm25",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pm25",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 140,
        "wires": [
                "cc7a7438.78d0f"
        "id": "cc7a7438.78d0f",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "object",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 630,
        "y": 180,
        "wires": [
                "7dca90ee.dd1e"
        "id": "99377a93.bbeef",
        "type": "change",
        "name": "set_topic_pm10",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pm10",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 200,
        "wires": [
                "cc7a7438.78d0f"
        "id": "7dca90ee.dd1e",
        "type": "function",
        "name": "Prepare json Data",
        "func": "msg.headers = {\n    \"Content-Type\": \"application/json\",\n    \"X-Pin\": \"1\",\n    \"X-Sensor\": \"raspi-xxxxxx\"\n};\nmsg.payload = {\n    \"software_version\": \"NRZ- 2020129\",\n    \"sensordatavalues\": [\n        {\"value_type\": \"P1\", \"value\": parseFloat(msg.payload.pm25)},\n        {\"value_type\": \"P2\", \"value\": parseFloat(msg.payload.pm10)}\n    ]\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 790,
        "y": 180,
        "wires": [
                "6062b7a6.f11b4",
                "7e61aafa.bdf9d4"
        "id": "6062b7a6.f11b4",
        "type": "http request",
        "name": "POST PM DATA",
        "method": "POST",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://api.sensor.community/v1/push-sensor-data/",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1000,
        "y": 180,
        "wires": [
        "id": "209ee0bb.85d3b8",
        "type": "function",
        "func": "msg.headers = {\n    \"Content-Type\": \"application/json\",\n    \"X-Pin\": \"11\",\n    \"X-Sensor\": \"raspi-xxxxxx\"\n};\nmsg.payload = {\n    \"software_version\": \"NRZ- 2020129\",\n    \"sensordatavalues\": [\n        {\"value_type\": \"temperature\", \"value\": parseFloat(msg.payload.temperature)},\n        {\"value_type\": \"humidity\", \"value\": parseFloat(msg.payload.humidity)},\n        {\"value_type\": \"pressure\", \"value\": parseFloat(msg.payload.pressure)}\n    ]\n};\nreturn msg;\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 790,
        "y": 300,
        "wires": [
                "781e1a98.6fd29c",
                "91343d53.60237"
        "id": "781e1a98.6fd29c",
        "name": "POST  DATA",
        "method": "POST",
        "ret": "txt",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 990,
        "y": 300,
        "wires": [
        "id": "e00d9f12.d75c1",
        "type": "change",
        "name": "set_topic_temperature",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "temperature",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 420,
        "y": 260,
        "wires": [
                "d31e430e.ec1b48"
        "id": "d31e430e.ec1b48",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "object",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "3",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 630,
        "y": 300,
        "wires": [
                "209ee0bb.85d3b8"
        "id": "1cb5402.8992d4",
        "type": "change",
        "name": "set_topic_humidity",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "humidity",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 320,
        "wires": [
                "d31e430e.ec1b48"
        "id": "ab77be26.de1d7",
        "type": "change",
        "name": "set_topic_pressure",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pressure",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 490,
        "y": 380,
        "wires": [
                "d31e430e.ec1b48"
        "id": "9339e84a.e1b108",
        "type": "json",
        "name": "",
        "action": "obj",
        "pretty": false,
        "x": 450,
        "y": 500,
        "wires": [
                "8b65c7d6.1a6228"
        "id": "834eb211.ed0578",
        "type": "mqtt in",
        "name": "tele/tasmota_E08D2C/SENSOR",
        "topic": "tele/tasmota_E08D2C/SENSOR",
        "qos": "2",
        "datatype": "json",
        "broker": "eec9b617.98a998",
        "x": 210,
        "y": 380,
        "wires": [
                "9339e84a.e1b108"
        "id": "2ac9c776.a95bf",
        "type": "function",
        "name": "offset",
        "func": "msg.payload = Number(msg.payload)+9;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 450,
        "y": 420,
        "wires": [
                "ab77be26.de1d7"
        "id": "8b65c7d6.1a6228",
        "type": "function",
        "name": "BME280.Pressure",
        "func": "var msg_pres = {payload:msg.payload.BME280.Pressure.toFixed(0)};\nreturn msg_pres;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 490,
        "y": 460,
        "wires": [
                "2ac9c776.a95bf"
        "id": "7e61aafa.bdf9d4",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 990,
        "y": 220,
        "wires": []
        "id": "38263145.35ea0e",
        "type": "ccu-connection",
        "name": "192.168.2.113",
        "host": "192.168.2.113",
        "regaEnabled": true,
        "bcrfEnabled": true,
        "iprfEnabled": true,
        "virtEnabled": true,
        "bcwiEnabled": false,
        "cuxdEnabled": false,
        "regaPoll": true,
        "regaInterval": "30",
        "rpcPingTimeout": "60",
        "rpcInitAddress": "192.168.2.113",
        "rpcServerHost": "192.168.2.113",
        "rpcBinPort": "2047",
        "rpcXmlPort": "2048",
        "tls": false,
        "inSecure": false,
        "authentication": false,
        "username": "Username",
        "password": "xxxxxx",
        "queueTimeout": "5000",
        "queuePause": "250",
        "contextStore": ""
        "id": "eec9b617.98a998",
        "type": "mqtt-broker",
        "name": "Mosquitto",
        "broker": "192.168.2.122",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": false,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": ""
I use the following data from my HmIP-SFD (SPS30) Sensor (Sensor Location)
  1. PM 2.5
  2. PM 10
  3. Temperature
  4. Humidity
Pressure comes via MQTT from my BME280 Sensor.
After Posting the data you can check incoming data
https://devices.sensor.community/sensors look at DATA .
Have fun…… :blush:
Great!
It works well?
The SPS30 measures also PM1, doesn’t it?
Yes it works well.
SPS30 measures PM1 but I have not yet found the right assignment for PM1 = value_type:P3?
current msg.payload looks like:
msg.headers = {
    "Content-Type": "application/json",
    "X-Pin": "1",
    "X-Sensor": "raspi-33553"
msg.payload = {
    "software_version": "NRZ- 2020129",
    "sensordatavalues": [
        {"value_type": "P1", "value": parseFloat(msg.payload.pm25)},
        {"value_type": "P2", "value": parseFloat(msg.payload.pm10)}
return msg;
PM1 is P0 actually. I forgot to tell you…
thanks for the info. :blush:
I have adjusted the NodeRed Flow below,
now with all particles areas of the SPS30.
        "type": "tab",
        "disabled": false,
        "type": "comment",
        "info": "",
        "x": 350,
        "y": 60,
        "wires": []
        "name": "PM_2.5",
        "iface": "HmIP-RF",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 140,
        "y": 180,
        "wires": [
                "6273c588.8e5af4"
        "name": "PM_10",
        "iface": "HmIP-RF",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 140,
        "y": 240,
        "wires": [
                "99377a93.bbeef"
        "type": "debug",
        "name": "",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1010,
        "y": 380,
        "wires": []
        "iface": "HmIP-RF",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 170,
        "y": 300,
        "wires": [
                "e00d9f12.d75c1"
        "iface": "HmIP-RF",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 160,
        "y": 360,
        "wires": [
                "1cb5402.8992d4"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pm25",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 420,
        "y": 180,
        "wires": [
                "cc7a7438.78d0f"
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "object",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "3",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 630,
        "y": 180,
        "wires": [
                "7dca90ee.dd1e"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pm10",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 420,
        "y": 240,
        "wires": [
                "cc7a7438.78d0f"
        "type": "function",
        "func": "msg.headers = {\n    \"Content-Type\": \"application/json\",\n    \"X-Pin\": \"1\",\n    \"X-Sensor\": \"raspi-12345\"\n};\nmsg.payload = {\n    \"software_version\": \"NRZ- 2020129\",\n    \"sensordatavalues\": [\n        {\"value_type\": \"P0\", \"value\": parseFloat(msg.payload.pm0)},\n        {\"value_type\": \"P1\", \"value\": parseFloat(msg.payload.pm25)},\n        {\"value_type\": \"P2\", \"value\": parseFloat(msg.payload.pm10)}\n    ]\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 790,
        "y": 180,
        "wires": [
                "6062b7a6.f11b4",
                "7e61aafa.bdf9d4"
        "method": "POST",
        "ret": "txt",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1000,
        "y": 180,
        "wires": [
        "type": "function",
        "func": "msg.headers = {\n    \"Content-Type\": \"application/json\",\n    \"X-Pin\": \"11\",\n    \"X-Sensor\": \"raspi-12345\"\n};\nmsg.payload = {\n    \"software_version\": \"NRZ- 2020129\",\n    \"sensordatavalues\": [\n        {\"value_type\": \"temperature\", \"value\": parseFloat(msg.payload.temperature)},\n        {\"value_type\": \"humidity\", \"value\": parseFloat(msg.payload.humidity)},\n        {\"value_type\": \"pressure\", \"value\": parseFloat(msg.payload.pressure)}\n    ]\n};\nreturn msg;\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 810,
        "y": 340,
        "wires": [
                "781e1a98.6fd29c",
                "91343d53.60237"
        "method": "POST",
        "ret": "txt",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1010,
        "y": 340,
        "wires": [
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 300,
        "wires": [
                "d31e430e.ec1b48"
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "object",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "3",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 650,
        "y": 340,
        "wires": [
                "209ee0bb.85d3b8"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "humidity",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 360,
        "wires": [
                "d31e430e.ec1b48"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pressure",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 490,
        "y": 420,
        "wires": [
                "d31e430e.ec1b48"
        "type": "json",
        "name": "",
        "action": "obj",
        "pretty": false,
        "x": 450,
        "y": 540,
        "wires": [
                "8b65c7d6.1a6228"
        "type": "mqtt in",
        "qos": "2",
        "datatype": "json",
        "x": 210,
        "y": 420,
        "wires": [
                "9339e84a.e1b108"
        "type": "function",
        "name": "offset",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 450,
        "y": 460,
        "wires": [
                "ab77be26.de1d7"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 490,
        "y": 500,
        "wires": [
                "2ac9c776.a95bf"
        "type": "debug",
        "name": "",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 990,
        "y": 220,
        "wires": []
        "id": "7ba02232.4e7db4",
        "name": "PM_1",
        "iface": "HmIP-RF",
        "datapoint": "MASS_CONCENTRATION_PM_1",
        "mode": "",
        "start": true,
        "change": true,
        "cache": false,
        "queue": false,
        "on": 0,
        "ramp": 0,
        "working": false,
        "x": 130,
        "y": 120,
        "wires": [
                "804459cf.c2b768"
        "id": "804459cf.c2b768",
        "type": "change",
        "name": "set_topic_pm1 = pm0",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "pm0",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 120,
        "wires": [
                "cc7a7438.78d0f"
        "regaPoll": true,
        "tls": false,
        "inSecure": false,
        "password": "pwd",
        "contextStore": ""
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
I tried to use the flow and it is working more or less fine.
Anyway, can you help me with some information. I use only the SPS30. How do I define X-PIN and software version?
To my knowledge the sensor ID is taken from the MCU (ESP8266) so how do you acquire an ID?
„Your version“ is not important. Write what you want. X-Pin should be 1. Check the api page in github.
I need some advice. How do I connect the SPS030 sensor to the ESP8266. Somehow I can’t get it to work. Thank you in advance for your help.
Sincerely Michal.
SPS30 (I2C, 5V)
Pinout: 1 2 3 4 5
Pin 1 (5V) → Pin VU/VIN
Pin 2 (SDA) → Pin D3 (GPIO0)
Pin 3 (SCL) → Pin D4 (GPIO2)
Pin 4 (SEL) → Pin GND
Pin 5 (GND) → Pin GND
Please check the pinout of the SPS in Google image.
And don’t forget to configure the sensor the right way.
There is an error in your SDS30 PM data forwarding to the proper P labels:
P0=PM1 (from SDS30)
P1=PM10 ,
P2=PM2.5 ,
Good luck, Bert
