A few weeks ago, I ordered my 1st pair of sensors.
The 1st one worked just as expected and a week ago I finally got around to finish the setup and it has been working flawlessly ever since.
The 2nd on the other hand didn’t work out-of-the-box. Besides the LED flashing and the sensor fan spinning, it indicated zero activity.
So I tried to troubleshoot it - but it shows zero output when connected via USB compared to the working one which just does what I’d expect.
So I assumed the supplier possibly forgot to flash it, so I flashed it using flashlatest.sh
$ esptoolpy=$(which esptool.py) esptool=$(which esptool) ./flashlatest.sh
usage: [esptool=/path/to/esptool] [esptoolpy=/path/to/esptool.py] [devserial=/dev/ttyUSB0] ./flashlatest.sh
writes output to listofflashed.csv
devserial=/dev/ttyUSB0 # define to change
nodemcuID sensorname hexchipID MAC revision:serial email lat lon locationaddress sensorID1 sensorname1 sensorID2 sensorname2
esptool.py v3.2
Found 1 serial ports
Serial port /dev/ttyUSB0
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: a8:48:fa:ce:ae:9b
Uploading stub...
Running stub...
Stub running...
Chip ID: 0x00ceae9b
Hard resetting via RTS pin... 0x00ceae9b 13545115
ask more infos? [y/N]
DBID esp8266-13545115 0x00ceae9b a8:48:fa:ce:ae:9b
a8:48:fa:ce:ae:9b : @ LAT LON LOCADRESS SID1 SNAME1 SID2 SNAME2
--2021-12-25 01:52:19-- https://www.madavi.de/sensor/update/data/latest_en.bin
Resolving www.madavi.de (www.madavi.de)... 2a01:238:42ae:3700:ef20:a9d0:cefd:73e9, 85.214.62.33
Connecting to www.madavi.de (www.madavi.de)|2a01:238:42ae:3700:ef20:a9d0:cefd:73e9|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://firmware.sensor.community/airrohr/ [following]
--2021-12-25 01:52:19-- https://firmware.sensor.community/airrohr/
Resolving firmware.sensor.community (firmware.sensor.community)... 2a01:238:42dc:ad00:8cc3:f820:67f4:ff2d, 81.169.210.193
Connecting to firmware.sensor.community (firmware.sensor.community)|2a01:238:42dc:ad00:8cc3:f820:67f4:ff2d|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1958 (1,9K) [text/html]
Saving to: ‘latest_en.bin’
latest_en.bin 100%[=============================================>] 1,91K --.-KB/s in 0s
2021-12-25 01:52:19 (100 MB/s) - ‘latest_en.bin’ saved [1958/1958]
flash now? [Y/n] y
to erase SPIFF (config data) use arduino IDE and https://github.com/esp8266/arduino-esp8266fs-plugin
see https://github.com/esp8266/arduino-esp8266fs-plugin
or overwrite SPIFFS now? [y/N] y
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting address from 0x00000000 to 0x00100000
setting port from /dev/ttyUSB0 to /dev/ttyUSB0
espcomm_upload_file
espcomm_upload_mem
opening port /dev/ttyUSB0 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
espcomm_send_command: receiving 2 bytes of data
Uploading 3125248 bytes from empty.spiffs.bin to flash at 0x00100000
erasing flash
size: 2fb000 address: 100000
first_sector_index: 256
total_sector_count: 763
head_sector_count: 16
adjusted_sector_count: 747
erase_size: 2eb000
setting timeout 25916
setting timeout 1000
writing flash
................................................................................ [ 2% ]
................................................................................ [ 5% ]
................................................................................ [ 7% ]
................................................................................ [ 10% ]
................................................................................ [ 13% ]
................................................................................ [ 15% ]
................................................................................ [ 18% ]
................................................................................ [ 20% ]
................................................................................ [ 23% ]
................................................................................ [ 26% ]
................................................................................ [ 28% ]
................................................................................ [ 31% ]
................................................................................ [ 34% ]
................................................................................ [ 36% ]
................................................................................ [ 39% ]
................................................................................ [ 41% ]
................................................................................ [ 44% ]
................................................................................ [ 47% ]
................................................................................ [ 49% ]
................................................................................ [ 52% ]
................................................................................ [ 55% ]
................................................................................ [ 57% ]
................................................................................ [ 60% ]
................................................................................ [ 62% ]
................................................................................ [ 65% ]
................................................................................ [ 68% ]
................................................................................ [ 70% ]
................................................................................ [ 73% ]
................................................................................ [ 76% ]
................................................................................ [ 78% ]
................................................................................ [ 81% ]
................................................................................ [ 83% ]
................................................................................ [ 86% ]
................................................................................ [ 89% ]
................................................................................ [ 91% ]
................................................................................ [ 94% ]
................................................................................ [ 96% ]
................................................................................ [ 99% ]
............ [ 100% ]
starting app without reboot
closing bootloader
…but it’s still the same - the output in Minicom is absolutely zero (same connection params, same cable etc as the working one).
Can anyone point me to resources on how to debug this further?
