My device does not show temperature, humidity or relative pressure, having installed a BME280, on my dashboard it shows those values but does not reflect them on the map, does anyone know why?
Can you tell me which dashboard you mean?
Please login to https://devices.sensor.community/ , click on “Settings” on the right of this sensor entry and change the components to the right type. You’ve registered a BME280 instead of a BMP280. These are different types, the BMP280 is measuring temperature and pressure, the BME280 is also measuring the temperature.
I didn’t see it! Made the changes now is works! Thanks
