Hi there. Newbie here. My sensor has been running for a week with data output to the sensor.community map and to Grafana. Today, no data is being shown on Grafana but it is still showing on the map. I’ve checked a few times this evening. Does anyone know why?
Can I have the ID on the map ? Or the geocoordinates (look in the URL adress when you have zoomed on your sensor) if there is no other sensor around.
Have you changed something here ?
Both the checkboxes should be checked.
I think it’s a grafana issue because i have the same since yesterday
here my sensor Grafana and no data anymore
if i choose other sensor in the list, same issue
Same here for both sensors. Everything is looking good on maps.sensor.community but api-rrd.madavi.de stopped updating yesterday.
You are right @ricki-z should be doing something in Grafana…
So @ricki-z
“Granafa (or better the receiving of data at api-rrd.madavi.de) should be up again.
There was an PHP update that disabled the curl module.”
It’s back for me
thx for the info @pjg
Sorry for the Grafana outage. There was an PHP update that disabled a function needed by the scripts. I have restored the old versions and the data should be shown again.
Thanks for resolving.
