Before I ask my question on TS, I ask here.
A French friend has a problem with his BME:
The data (T°/HUM/PRESSION) are not on the map, but they are well found: https://api-rrd.madavi.de/grafana/d/q87EBfWGk/temperature-humidity-pressure?orgId=1&var-chipID=esp8266-5672033
So its configuration is correct.
Do you have any idea what the problem is?
Merci
someone changed the API-PIN for this component from 11 (the default) to 3. But this is not the API-PIN our firmware is using to send data for this component. So the API server couldn’t assign the the incoming data to the BME280.
I have changed this in our database. The data should now be shown.
Hello, Thank you very much for your quick response.
I’m going off topic as you are in site maintenance: I sent an email to tech@sensor.community for the 4638 sensor that abnormal rates, this email still works?
Merci, obrigado from Portugal
