Hi
As I’m not very experienced with NodeMCU yet I’m a bit stuck.
I’ve bought the kit, assembled and flashed it but I get no data at all from the SDS. I think it’s power related (fan not spinning, no flashing LED) but I don’t know where to start with debugging. I’ve measured the SDS 5V and GND PINs and there’s voltage so maybe it’s the data connection.
As advised in the troubleshooting section I’ve redone the cabling several times, reflashed and replaced some cables to no avail. Pictures are attached, maybe I’ve gone insane while trying to figure this out.
During the setup I’ve flashed the NodeMCU after assembly, might that have caused an issue on the SDS? Would anyone have some advice on how to further troubleshoot?
Debug log
airRohr: NRZ-2020-133/EN
mounting FS...
opened config file...
parsed json...
output debug text to displays...
Connecting to 123
....SNTP synced: Wed Feb 17 16:13:16 2021
twoStageOTAUpdate
R/ SDS011 version date
/R SDS011 version date
HTTP GET: firmware.sensor.community:443/airrohr/update/latest_en.bin.md5
GET r: 200
No newer version available.
WiFi connected, IP is: xy
Starting Webserver... xy
ws: root ...
ws: values ...
ws: root ...
ws: status ...
ws: root ...
ws: values ...
R/ BME280
Temperature (°C): 21.26
Pressure (hPa): 97253.69
Humidity (%): 39.14
/R BME280
## Sending to sensor.community - BME280
## Sending to madavi.de:
Succeeded - api-rrd.madavi.de
Time for Sending (ms): 413
Device status
Parameter Value
Firmware version NRZ-2020-133
ST:1
SDK:2.2.2-dev(38a443e)
Core:2.7.3-3-g2843a5ac=20703003
lwIP:STABLE-2_1_2_RELEASE
glue:1.2-30-g92add50
BearSSL:5c771be
Free Memory 31200
Heap Fragmentation 3 %
Last OTA 6 min, 52s
NTP Sync 1
NTP Info 192.168.1.1 (?) reachable: Yes
Time (UTC) Wed Feb 17 16:20:11 2021
Uptime 6 min, 52s
Reset Reason Power On
SDS011
only errors
WiFi 0/-58/0
OTA Return 200
SDS011 2 <--------------increases
Number of measurements 2
Time spent uploading 492 ms
Current data
|Sensor|Parameter|Value|
|SDS011|PM2.5|- µg/m³|
|SDS011|PM10|- µg/m³|
|BME280|temperature|21.5 °C|
|BME280|air pressure|972.50 hPa|
|BME280|humidity|38.1 %|
|WiFi|signal strength|-51 dBm|
|WiFi|signal quality|98 %|![sensor |666x500]
Any pointers are much appreciated!
