NETTIGO data into influxDB v3
Dear all,
I thought that this topic may be of interest for many of you who uses Nettigo kits (and potentially also other particulate matter kits). Within AIRCONNECTS project in Austria ( AIRCONNECTS – Armengaud Innovate GmbH | Creating Impact. Together. ), we are about to establish a set of jupyter notebookes enabling work with NETTIGO (version Namf 47) for interested citizens. The goal is to be able to not only visulize (as is already granted by Nettigos option to load the data to madavi or sensor.community) but also to perform simple analyses (e.g. averaging, filtering, error correction) of the incoming data. We currently struggle with sending data to influx-DB version 3. Would you know if this option existsts / can be established? If I understood correctly, It is strongly recomended by influxDB to use v3 in new projects, Nettigo offers in its settings only v2.
Thanks a lot,
looking forward to hear back from the forum,
btw. great to have this forum,
Marcela
Hi @Marcela,
we would need to change the firmware for this. At the moment we don’t have the capacity for such a change for only a very limited user group.
But you could use the “own API” feature and use a forwarding script.The script will receive a JSON object with all the data and can convert the data to whatever you need.
(We started with InfluxDB v2 and would need to convert nearly a TByte of data at the moment… I hope we can switch to v3 next summer when the measurements may be “less interesting” and our InfluxDB instance can be down for a longer time.)
Dear Ricki,
thank for your time answering. Fully understand.
We will be looking forward for your update next year.
thanks so much for your work,
Marcela
