I am setting up a sensor using a PMS5003 connected to a Raspberry Pi Pico board. When I connect via my work network I am seeing many 408 - timeout errors. However if I connect to the hotspot on my phone it is working no problem.
Out I.T department is wondering if our I.P address has been banned. From this post https://forum.sensor.community/t/link-to-sensor-data-for-esp32/963/10 I don’t think that is the case.
The time between sensor readings is set to 180 seconds. I did try to make multiple upload attempts. I now have this set to wait 10 seconds between upload attempts in case that was causing a problem, but would still not explain the problem happening in the first place.
Can you offer any suggestions or anything that I need to go back to I.T with.
