Hi. I built the sensor and registered it only with SDS011. After a few days I added HTU21D. The problem is that the temperature and humidity values are displayed in the local interface (and on devices.sensor.community too) and Grafana, but not on the map. May be database issue (as I read in the forum). Thanks.
please go to https://devices.sensor.community/ , login and change the device settings. You should find there the configured components, these need to be the same than thos configured locally on your device.
Hello ricki-z. Thank you for solution. Both values are visible on the map.
(I tried to add a sensor in the settings at devices.sensor.community, but there was no possibility “add sensor/component” at “Hardware Configuration”).
I have exactly the same problem. I have accidentally removed my hum / temp / pressure sensor, and now cannot add back, as the “add component” button disappeared on devices.sensor.community.
The data is shown on graphana, but not on the map.
I have a nettigo-built kit with ID esp8266-1893309, SDS011 + BME280.
