Hi, I need help to determine if I can use the Heltec WiFi LoRa32 V3 as a receiver and the SX1276 LoRa Module as a transmitter for data transmission via radio frequency. By this, I mean whether they are compatible for connecting to each other.
Why not 2 SX1276 or 2 Wifi LoRa?
I used both with LoRaWAN successfully but I have never tried direct LoRa connection between both.
Anyway LoRa is a type of transmission. It should work and the price is cheap.
I want to connect different ones since I want to use the SX1276 as transmitter and the LoRa wifi as receiver to later upload the data to the cloud with the same one.
But if you want to transmit to the cloud, why not using LoRaWAN ?
This is my first time using LoRa so I am doing my research first.
