Little bug in Debug info (hPa instead of Pa)
When reading the debug info I found this
Sending to sensor.community - SDS011
Temperature (°C): 18.26
Pressure (hPa): 100559.28
Humidity (%): 74.79
The pressure must be wrong, it is too high by about two orders of magnitude. It should be Pascal, not hecto Pascal, or the decimal point should move two places to the left.
N.B. this is from the IPv6 beta version but in all likehood the error is also present in the regular version.
