I have a couple of unifi 6(lite/+) access points.
I’ve set up a specific IOT network on 2.4 GHz, which all my iot devices connect to.
Over the last 24 hours, it has lost wifi connection 12 times.
It is so bad, that I’ve gotten emails frequently about the sensor being lost for 24h, and I’ve had to set up a special flow that recycles the power if it can’t be pinged locally.
It’s a NodeMCU in the box. The box is placed outside a window, and there’s an AP behind the window 5 m away, so the Wifi is ok.
The sensor shows:
|WiFi|Signal|-60 dBm|
|WiFi|Kvalitet|80 %|
I don’t see these frequent disconnects with other ESP based systems. I have a lot of wifi switces etc. and they don’t disconnect all the time.
The sensors connected to the NodeMCU are a SDS011 and a BMP280
The PSU is a 5V/2A.
Is the firmware that bad that it will loose wifi that frequently, or what is going on?
