When being logged in, my sensor has this URL:
https://devices.sensor.community/sensors/43469/data
(The sensor itself has ID 75461)
When accessing the URL without being logged in, it redirects me to the login page.
I want to send a deep link to my sensor data to other people without them having to log in first.
The closest I came across was the map itself: Map Sensor.Community but unfortunately my sensor has to be manually clicked.
My question
Is there a way to have a public unique URL of my sensor data here on sensor.community?
pjg
October 3, 2022, 11:07am
2
https://data.sensor.community/airrohr/v1/sensor/SensorID/
But the 43469 does not return anything. Same with:
https://maps.sensor.community/grafana/d/000000004/single-sensor-view-for-map?orgId=1&var-node=43469
Are you sure it is the right number ?
https://data.sensor.community/airrohr/v1/sensor/75461/
should work (75461 was mentioned in the original post as the sensor ID)
If you register your sensor also on russian service https://aircms.online - you may access it by link like aircms.online/#/d/2678513. It’s not easy to do: the server is located in Russia so the site is on Russian and registration goes with Telegram messenger, but it made by good guys and it have some good features
