Hi everybody
I recently reactivated my 2 sensors but I can’t see them on the map.
They are correctly connected by wifi. I see the datas on my app “l’app matiere particulaire” for both of them.
I think I did forget something, can you hel me ?
|18089|esp8266-6199626
|21152|esp8266-1332281
Welcome!
Have you also checked devices.sensor.community ? There should be a checkbox which has probably be automatically unchecked because of inactivity.
Could you please check the firmware version? As you reactivated the sensors they may have a version with an old certificate chain. In this case HTTPS won’t work for APIs anymore.
Also the automatic update doesn’t work. So you need to flash the newest firmware manually. You config should remain intact.
