I can’t register my sensor again as I accidentally deleted it. ID is esp8266-14950228.
Hope you can help.
Kind regards Jos Jacobs
Hope you can help.
Hi @Jos_Jacobs , I’ve released the chipID. So you should be able to re-register it.
That sensor has died. I replaced it with tis one: esp8266-14778433 but ican not register it, because it reports it is already registered. Maybe release the chip-ID?
Hi @Jos_Jacobs I’ve restored the device registration.
