My PM sensor (ID 71164) is correctly logging and uploading data to this website.
The Temp/humidity sensor BME280 (71165) is not logging and uploading data.
When I browse to the device on my wLAN, I can see data from both sets of sensors are visible under the current data tab.
Typically, two sensors are attached to each node: the fine dust sensor and the Humidity and temperature sensor. The sensor number can also be found on the fine dust map again.
I’ve just realised that the configured device on the devices.sensor.comminity is a DHT22, vs the BME280 physically installed on the device. I think this missmatch may be the source of the error
Typically, two sensors are attached to each node: the fine dust sensor and the Humidity and temperature sensor. The sensor number can also be found [on the fine dust map again]
