How to update to NRZ-2024-134-B5
how can I update my sensor to NRZ-2024-134-B5 listed here sensors-software/airrohr-firmware/Versions.md at master · opendata-stuttgart/sensors-software · GitHub?
I checked the “load beta versions” checkmark in configuration but latest version I get is NRZ-2021-134-B4/DE
Thanks and happy new year
you need to flash the latest version manually. Instructions for this can be found at:
https://sensor.community/en/sensors/airrohr#Driver_and_firmware
Thanks. Will this keep my existing configuration?
Why is there no OTA update?
Hi. If you use the firmware flasher it will keep your configuration unless you tell it to do a complete erase.
OTA update in version NRZ-2021-134-B4 is broken so people running that version need to manually flash.
There seem to be some issues with NRZ-2020-133 though as well, at least in my case.
I put together a couple of sensors last year (around September), but I didn’t notice early enough that they were flashed with the previous firmware. When I did, as it was impractical to tear them apart, I decided not to risk updating with a long cable on, and instead let them update OTA. However, several months late and still no update.
Other firmware versions older than NRZ-2024-135/NRZ-2024-134-B5, including NRZ-2020-133, did have a working OTA update. But they also had a certificate, needed for the OTA update, that expired last year and effectively stopped working around the end of July last year.
That explains why your sensors won’t auto-update anymore and you’ll need to manually flash the latest firmware.
Note that I’ve done many updates over a 5m long USB cable without problems, never tried longer cables though.
Well, that explains it then. Thanks for clarifying.
Ups, forget to update this… Re-Flash the NodeMCU didn’t work and I even wasn’t able to delete the flash - so I used a new NodeMCU with the new software and it worked just fine.
